Not yet, but I was just about to investigate LED's to use. The face-plate just unscrews, so easy enough to do.
Please keep us posted if you do, including pics for those thickies like me
Just bought two kfa2 980 soc. Just reading up on some Temps . Are these generally fine then in SLI ?fan Sound isn't really an issue tbf as long as dosnt keep throttling , I'm running I an air 540 so assuming it should be fine . My two 970s generally throttled down 1 13mhz increment
They're hot. I've been playing around at the weekend with different fans etc (3 x 120, 2x140) to see what works best. The top one idles mid 40s and hits 79 during heaven (gpu fans at 100%), bottom one around 10-15 cooler. These SOCs are quiet though so the 100% things not a problem. 540r owner too.
KFA2 GeForce GTX 980 SOC Gamer 4096MB on it's way, 970 GTX G1 has an RMA number based on the VRAM scandal and will be returned once the 980 GTX arrives.
Gutted![]()
When it is all done and dusted you will be ok(ish) with your choice.
just waiting for the next fubar when Windows 10 arrives and we find that neither the 970 nor the 980 is truly DirectX 12 compliant - lol![]()
@ what clocks or is that at stock ?
I've spent the last week or so getting my head around my reference 980. The last few days I have been testing and tweaking my own Bios to force the boost clock to 1505 and mem to 3800.
One thing I've realised - some of the custom Bios's circulating are a lot of nonsense so if you're thinking of flashing make your own.
I have found no real benefit to adding voltage. All it does it increase the speed of the card hitting the power target. Also with the voltage above 1.225v my memory clock is unstable anything above 3650.
I have increased the TDP of the card to 340000 with a 100% power target. Completely stable with the above clocks @ 1.225v and undervolted slightly to 1.218v. I'm assuming there is no problem with running 1.225v with a higher TDP/Power target.
Will do more testing tonight but from what I've found unless you're pushing for massive clocks keep the voltage at stock otherwise it really does more harm than good.
Did you increase the power supplied from the PCI connectors?
I found that even upping volts in Afterburner would cause instability when I'm nearing my maximum overclock.
My SOC has arrived, solid looking piece of kit, very nice.
Looking forward to having a play tonight to see what it can do.
Will have a look at the BIOS later tonight as well.
Don't forget to consider flashing it with the latest BIOS if your fans are at 52% idle
