- 6 Jan 2013
- Rollergirl
Temp limit is at 91C / 122% Power Limit
What does GPUz list as the perfCap?
If you're planning on SLI in the future, why not go with the Reference design? There's even the EVGA Superclocked if you feel you need the extra oomph.So I've returned my 2x 970 G1 Gaming due to memory issue. Long story short, I'm going to go with 1x 980.
I can't decide between the G1 Gaming again, seems lot more money when it's on one card, or the KFA SOC which seems good value for money but a lot of you seem to be saying you're getting coil whine and high temps or any other suggestions? I may go SLI in future but for now I think I'm fine with whatever cooler if it comes with a recommendation from you all![]()
apparently it is because they can't find processors that will do the same clocks as the V1 due to demand so the v2 chips are binned lower
I can't believe it's getting to 74C with the fans at 90%
And there is no Perf Cap in GPUZ that I can see in sensors and the card still throttles when it hits about 73/74C
Run the installer from GPU Z, it's not present via the exe only.
Mine says something about vPref, which the techpower web site states is max GPU clock for a given voltage.
I'm happy enough as it's doing 1510 mhz on 1.2v.
You'll be limited with voltage and power no doubt.
Only way around it is to edit the bios
Power is fine, but yes it's voltage...
I've had this before with cardsI'll take a look later this week
I'll not give up! This beast has more ooomph in it
Right this is my 980 SOC bios
http://s000.tinyupload.com/?file_id=83491657924439154991
It is bios version 84.04.1F.40.06
I'd probably not recommend flashing this to your SOC in case you have a newer/older bios however it's just so you can see what I changed on the Voltage and Power Table tabs.
Default memory clock is now 3800 (7600 effective) compared to 3500 (7000 effective)
Power limit has been raised and now defaults at 250000 with a max of 290000
Voltages were tweaked slightly at the top (although whether this does anything as Maxwell is a PITA for voltage increases, I will check with a multimeter later)
This removes the GPUz Perfcap limits and still down clocks the card when not in use, although due to the way the boost table on this card is, the down clock isn't as low as the stock bios.
If you make these tweaks and flash your card remember to reset any GPU clocking software like Afterburner to defaults! With the extra power the card has now it will automatically go to it's maximum boost in the bios when gaming which is 1493 (check the boost table tab). So before you may of needed +150 on the core, now you will only need +50
Also make a backup of your bios and only mess around with the bios if you know what you are doing. I won't be held responsible etc.![]()
