Looking to get a GTX 980 coming from a 780 gigabyte WF3...
I see there are quite a few that are good but the stand out ones for me ATM are-
Gigabyte G1
Asus Strix
MSI gaming
Anyone had issues with theirs & what is you boost clock ?
I have 2 Gigabyte 980 G1's, out of the box one card will hit 1380Mhz boost clock, the other tops out at 1367Mhz. Haven't overclocked these cards so I have no idea what their full potential is.
I went from 2x EVGA reference 780 Ti's to 2x Gigabyte 980 G1's. The 980's are much better in VRAM demanding games, at 1080p game settings maxed out, games such as Shadow of Mordor (ultra textures) or Watch Dogs stuttered on the 780 Ti now run much smoother thanks to the extra 1GB of VRAM.
My 980's even run much cooler in SLI than the 780 Ti's. Even though I went from 2 blower cards with a single slot spacing, to 2 open air coolers they ran far cooler and permanently at their max boost clocks while my 780 Ti's could only maintain there boost clocks for so long before downclocking.
Even though the 980 G1's are factory over overclocked and my reference 780 Ti's were not, they still run much cooler (about 10 to 20c cooler in an ambient of 22c depending if I use SLI or not).
In an ambient of 22c and using SLI with Assassins Creed Unity (both 980 G1's average 80% load on both), the top GPU averages 74c, bottom 64c. On their own, each GPU rarely goes past 65c. When idle, again in an ambient of 22c they both average 27 to 28c.
Since going with open air coolers I have noticed my CPU averages 3 to 5c more when gaming (which I did expect) but gaming for hours in an ambient of 22c, it's extremely rare for my stock 4790k to break 60c anyway, tends to average 55c to 58c when gaming across all cores.
I love my 980 G1's, fast and very cool, and I just lover the all metal heatsink. It's a very heavy card but the build quality is fantastic.
The only 1 negative that I would give the card is the stock paste, it was like cement and both GPU's in an ambient of 22c the cards idled at 34c.
I could cleanly remove the paste my flicking it off in 4 large chunks, extremely bad stuff.
I put IC diamond on one GPU and Coollaboratory Liquid Pro on the other, both pastes run extremely close (at idle their temps identical, at load there is barley 2c in it if that) so I left each GPU with each paste. Both GPU's have been running 24/7 for close to 4 months without a single issue.
Sorry for a long post, I went on a bit
