Can anyone remember the mod that implements more lanterns around Skyrim? I can't remember what it was called.
Nice post fella
You've also reminded me about Imaginator which I used ages ago, and then got rid of. I use a heavily modified enb, but there are certain aspects I'm never 100% happy with that I can't resolve in the enbseries etc files. I think Imaginator may be a quick and easy tweak for some of them perhaps, going to give it a whirl...
Any of these, there is quiet a few hits searching for Lanterns on Nexus..
Lanterns of Skyrim - All In One
Lanterns of Skyrim - Around Cities
Lanterns of Skyrim - Bridges
Lanterns on the Roads
Thank you, glad you like the post and hope that the Imaginator will be of help for you.![]()
You Sir deserve a medal, thank you![]()
No probs, glad I could be of help.
Played a bit last evening and notice that the game was using like 5.3GB of RAM.. sure, I do have some HD graphics but should the RAM take such a hit ???![]()
Off topic I know but did anyone side with the reklings at thirsk hall?
Do they really come help you when you're in combat?
Is it worth it?
There any advantage to helping the Nord's?
That seems quite hefty imo. Mine uses around 2GB give or take a bit more. Usually a max of around 3GB.
My understanding is that it will crash at 3.1gb....
Only had it through Steams screen shoot facility and it don't capture the stats.. lolMy understanding is that it will crash at 3.1gb....
the 32bit system ram app limitations of the skyrim/tesv exe itself. Which is a limitation of skyrim itself. Hence why enboost go out of their way to move a large portion of it to vram.You talking about system RAM or vRAM?
To swede, make sure you are looking at the apps system ram usage specifically I.e not the os etc
Typing on tablet in bath hope I relayed clearly![]()
Ahh ok, might been the OS actually.. had task manager open this morning and the RAM was same on both... got to check Afterburner when I'm home from work and see if it has a function to show the app system RAM and not the OS...
Would anyone know of a mod or collection of mods that would be suited to starting a new game just for wandering around and exploring? Have everything you need after you exit the intro? Mounts, gear, etc. I'd like to do all the side quests from the start anywhere in the world.
- Wet and Cold - Dynamic wet and cold related effects, very cool and realistic
- Frostfall - Hypothermia player survival, must have mod
- Hunterborn - Realistic hunting, including the gathering of meat/pelts
- Weapon and Armour Fixes - 4 part mod, fixes bugs and incorrect settings for weapons and armours
- Smithing Perk Overhaul Remade - 4 part mod, better smithing perks and skill tree
- Clothing and Clutter Fixes - 4 part mod, fixes clothing ID's, weight, sizes etc
- Complete Crafting Overhaul - 4 part mod, huge overhaul of the crafting system
- Better Bows - New and improved bows added to the game
Does anyone know what mods I should use for a first time playthrough of Morrowind? I know it's the Skyrim thread but can't find a dedicated Morrowind thread.
Cheers.
