VROP, max operating volts. What is the default v, 1.2?
Stock is about 1.2 yeh, overclocked is this. Going to play DA:I now and see if it drops
That's not a bad clock or temps for the clock. I'd be happy with that.
What are the FTW cards boosting to out of the box?
If you're referring to the overclock.net bios dude I really wouldn't bother. Just increase your voltage table, clock voltages as well as power target. Saying that, It's only worth increasing the voltage if you need to.
Get that memory up a bit my EVGA SC does @1544/4112 with no mods on air.
Yay, fan curve sweet spot found, 70% fan maintains 75/76ºC temp at full gpu load![]()
Well, my FTW has just turned up and like the Galax SOC before it, DPD have dropped it during transit.
So, this one is going back for a refund. I think I may well give up on the GTX 980, or at least from OcUK as I need a working machine this weekend.
Gee.....
Gee.....
Gee.....
