- 20 Jun 2011
- Livingston
Its not quite that straight forward with mine as apart from one row they are set to 1.262v already yet the card is only using 1.206v whether its 1392mhz or 1542mhz core.
As it is a voltage range from say 1.206v - 1.262v you will need to set the top sliders minimum values to 1.262v if you want to force this voltage.
If 1542 core is your max stable core clock this should appear as #74 on your boost table. Your voltage table for CLK 74 should read 1.262v - 1.262v.
I soooooo hope a firm brings something like this out for the 970/980s !
