Will a single GTX970 work with this monitor? Also the card I have has miniDP connections (and 1 HDMI). Will I be able to connect to the monitor.
Yes it'll work, you might have to lower some settings to get high FPS though depending on the titles played.
As for connections, it requires a full sized DisplayPort connection, so you'll need either a MiniDP to DP cable or an adapter that does the same.
Thankyou. That's very helpful. While my heart says yes about this monitor, I think my head is going to have to over-rule it. At £600 plus that is more than half the cost of the PC I'm getting. I think I will have to stick with a standard 27" 60hz machine for now and wait for deflation to occur in the country and pick it up when the price falls![]()
Has anyone gone to one of these from a DGM IPS-2701WPH? - I've got money burning a hole in my pocket and looking into getting a G-Sync monitor.
im thinking of upgrading to this monitor from a SA850T, my pc specs are in my sig
im only concerned about image quality, as its a big deal to me not been a huge fps player
I'm in a similar position, got a Hazro 27" 1440p but the Asus ROG is so tempting. My head tells me it's not worth it but still...
So, any fellow swift owners considering selling theirs now the Acer IPS 144hz gsync has shown itself to be rather tasty? http://www.tftcentral.co.uk/reviews/acer_xb270hu.htm
I'm contemplating it, before prices on the swift start to tank, and then pick up a 34 inch superwide ips or VA 144 Hz gsync monitor later in the year, which is bound to happen now. Thoughts?
