Planes aren't water tight.Assuming the plane landed completely intact on the ocean, as it sunk the pressure would have broken the structure, so why hasn't debris of some kind floated to the surface, if it has then it'll presumably was ashore or be discovered at some point.
Most likely killed (it's never been heard of for both pilots to commit ariel suicide). According to the Air Crash Investigation episode on MH370 it would have been easy for the captain to order the first officer out of the cockpit for some reason (get him a coffee) then lock the door and disable the cabin pressure, knocking out and killing everyone in the cabin (cabin air masks only last 10 minutes whereas cockpit masks last hours).
The only three feasible explanations: pilot suicide or hijacking, and the chances of hijackers gaining access to and control of the cockpit without either pilot getting a message out (something they have a variety of ways to do subvertly) is next to none.
Surely would still snap in half on it's journey to the sea floor?
It doesn't need to be airtight to get crushed either, the weight of the water does the crushing not some magic with an airtight container
Well no there needs to be something watertight for the pressure to crush it.
Otherwise the water just flows inside and now the pressure is equal inside and out and there's no crushing force.
If you ever watch the video of the train tanker being sucked to vacuum then getting crushed by the atmospheric pressure it demonstrators quite well how powerful a pressure differential is.
You mean like water?on the atomic level it's amazing how many materials contain oxygen![]()
The air needs to leak out for it to sink though, Arknor's right to a degree, stuff like the tyres and the fuel tanks will almost certainly collapse under the pressure, but the actual external skin will remain almost intact on the way down not allowing any internal debris and loose items to get out.And if the leaks can't equalise the pressure as it sinks it will implode or fracture at some point.
It can be done though, at least two examples of a large aircraft being landed intact on water that I can think of. Fair enough, if it was 50 foot seas that day it's not going to happen.Landing an aircraft on the sea in one piece would be considered a miracle in aviation especially a 777.
It's nothing to do with materials containing oxygen or hydrogen as to whether they collapse under pressure. It's the differential pressure between the outside of something and a void on the inside (either a vacuum or containing a compressible fluid ie air in this case) and the solid structure not being mechanically strong enough to resist the forces.I was thinking like plastics, the tyres on the airfraft, carbon contains hydrogen ? theres loads of things on a plane that can crush at it falls to the sea floor what about the fuel tanks which is pretty much the whole wings? surely they would fall apart
I would put money on it being done, given the complete lack of debris that's turned up even now, the best part of a year later.It's do-able but it being a 777 would mean my money would be on a fairly substantial impact and breakup rather than a smooth Hudson style landing even in calm waters.
Or quite possibly that!Or it's sat in a hanger somewhere awaiting the next 9/11...
