- 5 Jul 2007
- London
Ah. I'm coming at it with zero decent components to offset the cost. I do like the look of the Rotor 3d+ stuff but think I'll probably have to stick with standard Ultegra bits to keep the costs down.
Yeah, I really like the Rotor cranks, that said I'm kind of stuck with them as I use 165mm and a Power2Max.
When I first tried them I was spinning so much easier than with anything longer, so it was academic really.
. I went to them and got set up on this rig which was adjustable in all ways, and we just worked until we have my most comfortable fit. From there we looked at all the bikes with geometry that would suit. It meant buying a 58cm Cervelo P3, a size I would have never ended up on otherwise. And I've put about 1700 miles on it since, with about 5-6 100+ mile rides pretty solidly in the aero bars.
