Check Internet connection is enabled during rest. Had the same issue, turns out a firmware update disabled the option.
Yeh, it was all set OK, just not working properly.
I actually get this issue with both my X1 and PS4. They both seem stubborn to download updates when on standby, only occasionally doing what they are supposed to do.
http://blog.us.playstation.com/2015/03/11/ps4-update-2-50-yukimura-preview-suspendresume-and-more/
60 FPS remote play means I'll probably actually use it now.
I don't normally leave mine in rest, but it shouldn't matter. The option for keeping stuff up to date automatically, says it should work in either mode.
It used to before I unticked the box. Would switch it on, and if there was any updates, the notification "X has been added to downloads" would appear.
Since doing that, even with it ticked, it just refuses to grab them unless I start the game or tell it to.
What is this feature in the upcoming firmware?
"Sub-account to Master account Upgrade" can now be done from the PS4.
what is a sub account![]()
Pretty sure, if you have lots of games installed, it will only automatically check for the more recently used games. But I don't know the exact number it will automatically check for.
It was a type of account designed for children which would sit under a parents account. It was limited it what features you can access, and as PSN is nearing 10 years old a lot of people with these accounts are no longer children and want to upgrade their account to a full account. This (finally) lets you do that.
Great update but what will get cocked up afterwards? Something always does.![]()
Why just add the ability to remove 0% trophies? Why not ANY trophies?
I mean why are they so fixated on it being set in stone once you earn any.
You often get 1 trophy for basically starting a game so.
I'd just have 2 folders under trophies for 100% only and everything else or the ability to show all.
Ah well...i don't care about them anyway just always wondered why they were never very flexible about them to start with. It's not like there is any inherent value tied to them so just give people total control over what is kept and what isn't.
Mind you, I am the type of person who deletes e-mail or message chains constantly so maybe I do have a bit of OCD about clean, concise display of information.
I'm similar, I keep getting Drive Club invitations to beat this persons score or lap time. I don't want to beat their score or time and I don't want notifications either, I hardly ever play it any more. I've no idea how to stop them.
