- 10 Jan 2009
- Now live in Scotland !
also how do i install the drivers ? ICC ?
Just booted pc up and my monitor was going crazy craxy flickering and going off and doing it for about 2 mins and now fine .. what the heck is this ? also i got light bleed in all corners when there is no imput or a film with black bars , not on ink black background but its there . slightly worried about this flickering and then blank screen and so on for a couple of minutes . Im thinking problems are going to start to arise as maybe philips are yanking these out in double time due to demand .and over seeing there QC .
You do know that's an MST and not an SST screen right ?
"Readers who have been keeping a close eye on 4K developments will know that earlier displays utilised Multi-Stream Transport (MST), forcing the initial batch of 4K panels to be recognised by the OS as two, or more, displays tiled together. Such a setup was hardly ideal, and the new scaler technology built into the AOC panel is a marked improvement - hook it up via DisplayPort and it's instantly recognised as a single 3,840x2,160 panel with a 60Hz refresh rate.
DisplayPort 1.2, then, is the connection of choice, however HDMI 1.4 (with MHL compliance), DVI and VGA inputs are also provided, though do be aware that using either HDMI or DVI limits refresh to 30Hz. A 3.5mm audio jack is provided for the integrated 3W stereo speakers and there's also an integrated four-port USB hub, with two connections offering SuperSpeed 3.0 capability."
http://hexus.net/tech/previews/monitors/70233-first-look-aoc-u2868pqu-4k-monitor/
Not going to offer 1:1 pixel mapping neither I would guess, native res or nothing. It's a tv, not a monitor.
but even with 3 way sli 980s and 5960x it still cripples it but getting 60fps with AA turned off .(cards not overcloked) .
anybody suffer any bleed in any of the corners ? rain forest are replacing the screen once they have more stock and i can use the screen until then . thats good of them .
is it not the case you are sitting close to a VA panel so the colours shift due to it not having as good a viewing angle as an IPS screen, I do notice that on mine but if i go back a bit it is fine.
