The largest 2.5" 7200rpm drive I can find is only 1TB..What is the largest 7200rpm drive that will fit into a ps4?
So I did some drive swapsies, and now re-installing everything by re-downloading. Talking like 800GB's here.
Anyway today Sony release an FW update which allows you to copy all your data to external HDD and then put it all back on...
This would have been lovely yesterday !!
Yeah saw this. Going to make my life easier when I eventually upgrade.
yeah very handy feature for any future hdd changes.
Can the transfer be done to a usb stick?
Im thinking about getting a 2tb down the line but when it comes to backing up I will only have a few games I will bother about such as bloodborne and maybe driveclub which are my only digital purchases.
I have a 1tb sshd in mine at present, If I were to get one of these external 2tb drives would I be able to stick either the 1tb back in the casing or maybe the original stock drive and use it as a backup hdd (seen as we now have the feature)
Im also not sure if its possible to remove the 2tb drive without breaking the caseing its in?
thanks.
Yeah it's really easy, the lid just pop off. You pull out the drive it's not attached to the casing so nothing gets broken, then un wrap the silver foil around the drive and unplug Sata / Power bracket. Then you can use all that for whatever else you want to put in. I put an old 500GB laptop drive in my empty case and 2TB in PS4 (Did have SSD). No idea where my original PS4 HDD is, I think I may have given it away. Hope I don't ever need to RMA it
Brilliant, what 2TB have you got?
Never mind lol realised your the op!
Cheers
