Man of Honour
- 13 Nov 2009
- Northampton
Just do some burnouts....
That would require enough power to keep them spinning once they've broke loose
Yeahhhhhh......Just do some burnouts....
Exactly.That would require enough power to keep them spinning once they've broke loose![]()
I'm fairly sure the only way to lose traction in that car is via understeer, I'm not sure it can break it from power (or the lack of).![]()
what did u use on the exhausts to get all the crap off?
I couldn't find my usual Autosol, nor the wire wool, so I gave them a very gentle clean (very little pressure) with Cillit Bang and a Brillo padWorked a treat and seemed to remove a fair amount of carbon deposits. There's still a few more which will need a bit more elbow grease but I'll wait until I've got some double/triple 00 grade wire wool.
370z? Saw my first one on the road last week, great looking thing.
What have you done to your car today?
Is that the genuine Nismo wheel? Looks good.
e; wait, I clearly cant read. Looks similar to the Nismo one, only with a flat bottom.
