but ... it's quite noisy![]()
I have mixed feelings about this, on the one hand I’m glad people are getting their Titans, on the other hand I hate you all.![]()
but it's very noisy even with the case side back on, it's like a hair dryer on low, it's easily as noisy as the 7990 but it's a constant noise, where as the 7990 used to pitch up and down as it throttled back.
Is the noise really that bad?
Haven't stressed mine yet. Also my QDCs still not shown up... 9th day since ordering now![]()
I don't mind a bit of noise during games, but I really do appreciate silence when not playing games.
yes i am quite shocked about it and feeling a bit depressed right now, it's powerful yes but considering it has no overclock and only at 1080p, it's way too noisy.
fan is on Auto
there's no noise when you're not gaming, but as soon as Heaven is on the noise starts when the temp gets to 80 degrees and continues for about 30 seconds after you exit, the temp holds steady at 84 degrees but the noise is the same level as the 7990....
as said it's not a total disaster, but it deffo needs water, if not i'm going to send it back...right now i feel very depressed
So set up a Custom fan profile in AB. I never run stock fan settings on any card.
show me how please, or upload a pic
thanks
thanks
Have you got Afterburner installed?
http://www.guru3d.com/files-get/msi-afterburner-beta-download,26.html
