actually im not using the Tri-x only the R9 295x2 that was only for testing and benchmarksHow come you have it in the bottom slot?
... And when you wanna use only one gpu that`s the only way, with the r9 295x2 as primary is not possible that i know... but not sure
just got mine ..... so happy with this card ...
actually im not using the Tri-x only the R9 295x2 that was only for testing and benchmarks... And when you wanna use only one gpu that`s the only way, with the r9 295x2 as primary is not possible that i know... but not sure
edit: Is my first crossfire build ...
Correct, you can't actually run just 1 GPU with a 295x2 unless there isn't a crossfire profile in which case it does it automatically.
Welcome to the club.
Few suggestions for you.
1. Swap the cards round, it will work better temp wise.
2. Turn your psu over so it sucks out the heat that the Tri-X dumps in the case.
3. Make sure the 295x2 Rad is exhausting out of the case.
4. High static pressure intake fans at the front of the case.
5. Remove any spare pci brackets.
Interesting suggestion with the PSU - won't that heat it up though?
How is GTAV running on this card?
Runs very well so far, I've got everything pretty much maxxed with 4x MSAA and "AMD CHD" shadows (whatever that is) and it achieves 55-60fps at a vsync locked 2560x1440. Seen one brief drop to 40ish fps.
Good to hear. Was expecting a few more fps though?
I'm struggling at 1080p on the 295 X 2 I'm sure it's drivers though (i'm on windows 10)
I've tuned settigns to high and reasonable to try and maintain 120 fps but still getting weird drops.
I do need to OC my Cpu though.
too many variables Chuffed with the game though.
