Had a quick play around earlier with VSR. Upped the res as high as it could goto, 3200 x 1800, added Fxaa and turned off msaa, and it got rid of a lot of jaggies.
Usually play at 1080p with 8xAA, and it definitely looked sharper like this. Didn't seem to have any negative impact either as the FPS stayed the same. That's using 3x 290s so might have more spare oomph than others but could be worth a go for some folk.
Also noticed that gpu usage is much steadier now after doing comparible runs of the two settings. Quite often a card or two is maxed out for a period of time, where as before it simply spiked and dropped.
