Does anyone know any config tweaks at all that would help with performance ?
People will be able to help just tell use your gfx card and will recommend the settings to use
Tried turning off the nvidia streaming service? Apparently it helps gain 5-10fps
Thank you I have turned it off and disabled it now. I'll see if that imroves things, are there any more tweakies ?
Great fun so far, only worry is the combat is just repetitive and a little lacking in much of any kind of tactics/depth so its going to become stale pretty quickly.
Depends what setting you play on. If you play it on hardest kinda like it is meant to be played no fight will be the same and you will need potions/food.
Have you tried this guide: http://www.geforce.com/whats-new/gu...-hunt-graphics-performance-and-tweaking-guide
It tells you which settings are most demanding so you can reduce the right ones. I don't think there are any 'freebies' in the config that just give you boosted FPS.
.Depends what setting you play on. If you play it on hardest kinda like it is meant to be played no fight will be the same and you will need potions/food.
Looks like there is big patch coming next week, 600 changes including graphic improvements
http://www.eurogamer.net/articles/2...he-witcher-3-graphics-downgrade-issue-head-on
So who else made the set of Viper swords ? One for silver and one for Steel![]()
