Any new AMD drivers for this
I just had a crash
Not yet.
http://support.amd.com/en-us/kb-articles/Pages/The-Witcher3.aspx
I just had a crash
My gamma option seems to have disappeared. Don't have anything in the menus
I know it just aint there.. Think only 1st time you start the game :S
I cannot master the combat... may have to reduce the difficulty. I seem to be bested by small children
You can access it from the main menu when not in game like this:
If it has vanished then lol
The patch 1.03 has just been released and is now available for all PC version of The Witcher 3: Wild Hunt. The update introduces a range of stability and performances ehancements as well as allows users to take advantage of some additional graphics settings. Please find the detailed list of fixes below:
Improves stability in gameplay and the UI
Improves performance especially in cutscenes and gameplay
Fixes grass and foliage popping that could occur after density parameters were changed
Improves Nvidia Hairworks performance
Boosted texture anisotropy sampling to 16x on Ultra preset
Sharpen Post-process settings extended from Off/On to Off/Low/High
Blood particles will now properly appear after killing enemies on the water
Corrects a bug where player was able to shoot bolts at friendly NPCs
Improves menu handling
Corrects an issue with Stamina regeneration while sprinting
Fixes a cursor lock issue that sometimes occcured when scrolling the map
Generally improves world map focus
Improves input responsiveness when using keyboard
Corrects some missing translations in the UI
Corrects an issue in dialogue selections
Rostan Muggs is back
Minor SFX improvements
Heyo, if you're not seeing the Gamma option then you are playing in borderless windowed mode. Game has a tendency to switch from fullscreen to borderless windowed at times! Should help with FPS if you put it back to fullscreen too!
