- 18 May 2010
- London
Yes its a very strange game performance wise. Low vram usage but very demanding in the processing (GPU) side.
Looks like new Nvidia drivers are out as well: 352.86
Been out a few days.
Consoles are using upto 6GB ram at poorer settings, so must be using more than its showing. Do PC games also use normal ram for game stuff?
Going full screen has 100% helped, staying at a rock solid 60fps now instead of fluctuating between 50-60 indoors. At that herbalists women's hut and was was about 50 inside now a full 60.
Next gonna try the patch and see if rolling back drivers helps on 780. Only two settings down to high, foliage distance and shadows, want to see if I can eek out some extra performance to turn foliage distance back to ultra.
HairWorks looks fantastic and even better since the latest patch![]()
One thing I have noticed since the update is that as you race through town etc on the horse or even running, people seem to pop in out of thin air. Sure that's new.
It's been happening for me since the start. Not all of the time, just occasionally.
One setting that seems pretty useless is the background characters one. It changes the amount of NPCs that can be rendered at the same time, wirh the lowest being 75 apparently.... But you will never have more than that on screen surely?
Getting tired of nvidia drivers crashing now.
