I've just completed the Ladies Of The Wood quest. Very creepy!
The patch has been great, I've played for hours tonight without as much as a stutter let alone a crash. This game is fantastic.
Yeh Johny part and then ladies of the wood is some good stuff!
have fun
I do recommend turning down the sensitivity a bit though if you're using a controller, makes the game feel a little bit less twitchy, and helps with the annoying looting/"use" system. I also really enjoy Geralt as a character, quite cheeky
