Man of Honour
- 21 Nov 2004
Any ph neutral snow foam (like the ValetPro stuff) should be okay on the autoglym stuff. With the SRP though it's going to be pointless and expensive putting it on and leaving you need to seal it with either a wax (like FK1000p, cheap and has a decent lifetime) or a sealant (better on light coloured cars, Sonax BSD or C2V3 are two quick ones, spray, spread and buff).
Regarding tar removers, tardis is thought of as the best just use with common sense![]()
Gloss Protection will be enough to seal it, but yes, waste of time if not sealed. I use HD wax, leaves a lovely finish. Have just bought the G3 applicators which should make putting on SRP much easier.
Looking at the snow bottle that comes with the Nilfisk 110, doesn't seem to get good reviews. There is another red snow lance by Autobrite that seems to get good reviews, can't find anything better at the moment!
