- 29 Dec 2009
With the new batch imminent, are you not tempted to try again?
I have one of these in my basket ready for checkout, after reading this thread though I'm not too sure whether to gamble on getting a good one or not as it's a fair chunk of wedge for a monitor.
Same!! What have you read? Specifically?
I was debating between this and a 34".....
I’ve got one of each of the following right now:
LG 34UM95 (34”, 3440 x 1440, 60Hz, 21:9 Superwide)
Acer XB270HU (27”, 2560 x 1440, 144Hz, G-Sync, 16:9)
Depending on the content different panels suit best.
The LG superwide is best for general OS stuff, web browsing, emails, music/image editing, Excel etc, some action games (Assassin’s Creed and other 3rd-person stuff), RTS games etc. Going to this for the first time was like going from 4:3 to 16:9 for the first time again. There’s so much screen real estate! Side-by-side viewing of docs/progs etc is blissful, you’re talking the productivity of a dual-monitor setup but without the bezels, and of course a nice wide viewing port for gaming. Switching from this to regular 16:9 is quite jarring, you feel something is lost.
Not everything is supportive of this aspect ratio, but with a bit of work and the help of the Flawless Widescreen app most things work, although you have to settle for what is essentially a cropped FOV on some titles. Newer stuff seems to support wider ratios more readily.
To be honest, if my superwide wasn’t capped at 60Hz I wouldn’t have gone for the Acer, but I needed something that can handle 75/90Hz for ease of use with my Rift DK2 (you need your panel to match the refresh rate of the Rift to avoid judder on the HMD). Plus I wanted to see what life was like above 60fps.
The build quality, design and overall feel and look on the LG is really tight, it is a beautiful piece of kit.
The Acer has been problematic – poor bezel design and construction makes for backlight bleed in the corners (especially the bottom right) and there’s more noticeable IPS glow than on the LG or other IPS screens I’ve owned/used. The OSD/menu is basic and not very nice to navigate. Colour reproduction is good and the pixel density makes for tight viewing. 144Hz is lovely (when you can reach it!) and G-Sync makes for fluid viewing, but the screen I’ve got seems to lock up my GPU(s) on a regular basis… but it seems not many have suffered with these type of faults, and are more concerned with the bleed/pixels etc.
Oh and you’ll want a bracket or another third-party stand as the supplied one is a bit poor.
Thanks for your comment.
I've been using a 1440p 60hz panel for some time now and I've had no issues with FPS games (BF3/4/Hardline) at that speed which is why I'm still considering the 34". I already have a 27" so my logic would be to get the 34" and see how I get on. Considering the prices are not that far apart and the issues being reported with the unit in this thread, this pushes me more towards the 34".
The other side is that I've yet to experience and try g-sync!
Just a heads up, I was told when I asked that they are now expecting the new batch the week commencing 1/6/15.
