Was it this monitor that people were mentioning problems with gaming? Ghosting etc?
tbh this monitor as slight ghosting. but it's not too bad..
So would this be more than capable for fast paced games such as FPS?
Thanks![]()
I find the 4K TVs to be slower for gaming and not really better for anything else (at the same price) which makes them a bit pointless atm imo.
Wildest - PWM, At less than 100% brightness some people's eyes are sensitive enough to make out a slight flickering which increases as the brightness is reduced. The % of people this would effect is fairly small but it can be an issue.
As to HDMI 2.0, this monitor uses Display Port (DP) 1.2 to provide a 60Hz 4K image where as the HDMI and DP 1.1 (which are also fitted) only provide 30Hz 4K which, from what people on here have said, is very poor for gaming.
With regards to the DP 1.2 is there only 1 port of this type? Ideally I would like to connect both my xbox and PC @ 4K 60HZ (not sure if there is even a benefit to doing this).
Thanks again![]()
2 ports. min DP and normal DP....
tbh it's a good monitor for gaming, it just as a slight ghosting. i don't notice any input lag.
theres no benefit to connecting an xbox at 4k 60hz, the thing cant push games at anything more than 1080p at 30hz as far as im aware, so save the displayport for your PC and stick the xbox into an hdmi port for upscaled 1080 @ 30
Do you think there would be more ghosting on a normal 4K TV compared to this monitor?
