Caporegime
- 18 Oct 2002
I limit mine to 59hz and mine are very quiet when gaming
Yes it will.
Yes! I was running my GTX Titans with v-sync and it reduced the noise/temps.
So from EVGA direct £550 for the Superclock+ with ACS 2.0+, not bad really.
Hydrocopper is £638 which given the cost of a block, backplate etc. isn't bad at all
Thanks! I'll be sticking with 60hz for quite a while so that does make it temping to maybe grab a Ref over a Hybrid then, decisions decisions!
*Grabs a wad of twenties and pops to bank*
How do you go about this?
I use riva tuner to limit my fps to 65 in all games. Most games will have vsync, I assume you are doing something similar?
On the fence whether to get EVGA Reference or their ACX cooler. Are Reference coolers significantly louder than the proper coolers? I'm thinking for sli later on how much of a difference reference would make.
Anyone know if prices are likely to fluctuate when AMD release the 390x?
I really think it can depend on your case cooling, I've personally always found the ref coolers (That expel the hot air) to be quieter than the blowers in my case.
As this card is cut down like the 970 I have to ask, has anyone tested if it's 5.25GB? ^^
I'm actually being serious, I wouldn't put it past them to pull it again.
780/780Ti from the MM?
Tricky decision. The Hydrocopper looks like a decent deal, but I guess it may hurt re-sale value?
Then again, how long will the wait be for aftermarker 980Ti blocks?
