Very odd indeed! I removed them manually as I assumed they were for SFX. The crashing persisted though, back on GR drive and no issues![]()
Unfortunate, hopefully they fix it soon. The patches seem to be hit and miss for people.
How do notice boards work? I took all the notices off the White Orchard board but I don't appear to have anything in my quests list for them, they do not appear to be in my inventory so that I can read them and there are no new markers on the map. I'm confused! lol![]()
They are not all quests.
None of them appear to be quests for me.
They are not added to my quest list and they are not in my inventory either even though I took them off the notice board. Bug perhaps?
Some are quests some are not, if you pick up a quest one it will add the quest.
Every time you revisit a notice board it will re populate with non quest notices
)also check the map before you take the notices, i find that the noticeboards sometimes add ? icons to the map so they are not just for quests
I have done all of the ? locations so perhaps it was one I didn't realise got added to my map. I kind of mopped up the ? locations last just before going on to fight the Griffin.
I found the giant bear at one of them hardest thing to kill in the game yet. Griffin was a piece of cake compared to that thing!! lol
Is it just me or is the crossbow pointless? It seems to do so little damage i just havent bothered using it. even with upgraded bolts. Can you get a better one/ make it better in anyway?
I only find it useful against multiple flying enemies using the quick shot really, you get some Witcher Gear Crossbows you can craft at higher levels.
.Sailing across the Skellige isles looking for armour is pretty epic. Especially at 40".
Have you encountered a storm yet?![]()
