Hmm, I'm getting similar temps with a Fractal S36 (360mm AIO). I'm wondering if it's shoddy TIM between the die and the heat spreader.
Maybe I'll try re-applying paste and re-seating the heatsink.
Is it worth waiting for the kylake platform 6700k and ddr4?
Cheers mateI'm on the verge of a 4690k for 125 but like me I'm tinkering on 4790k...or a Xeon E1230v 3 for 164
After the 45 I get for the g3258...I can't clock the Xeon but it's got 8mb cache and HT
(Q6600)What is the recommended Motherboard and ram to go with the i7-4790k
Bonus test for lulz...
Spare PC(Q6600)
Wait and mm will be flooded with 4th gen stuff when skylake hits in August
In general what sort of max temps are you guys getting with your oc? I've yet to have a proper play with overclocking mine. I've also heard that batch L4 is better than the L3? I've got an L3![]()
The new Devils Canyon ones run a lot cooler.
Just decided to dabble with Overclocking.
Currently at 4.6ghz on 1.22v at the moment slowly lowering it to see how low it can go. Then I will go the other way. Did a quick 4.7 and it failed on 1.24v after a crash in Windows so probably need a bit more but should do 4.8 okay.
At the moment Max 74c stress test and around 55c in games I've been playing.
Geez just seen them at £275 on OCUK. Got mine for £215 Retail version few months ago with free game from a four letter competitor.
I've currently got mine at 4.6 on 1.265. Max is 70c in stress test. Doesn't seem to be the best clocker.
I know, it's mad. I got mine off the MM for £175.
I bet you are playing with all the other fancy settings though? I just play with the voltage and the multiplier. I don't really understand the rest, i've tried to make sense of it but i can't seem to get it.
Nope, i'm only using multiplier and voltage. I'm using offset voltage.
