- 9 Nov 2014
YAY!
YAY!
And where Sir if I may ask, where are you putting the mouse padYAY!
I seem to have developed a fault with my card. After an hour or two of use, it can be desktop, YT, Twitch, gaming, anything, my monitor starts to flicker on and off, and I get multiple driver crashes. These can be together at the same time, or completely separate.
Anyone else had this issue? I want to believe my card isn't broken, and it's an issue with the drivers since g-sync now works on the desktop, but I put one of my old 780s in yesterday for a couple of hours, and it worked fine.![]()
Have you got a new desk?
As well as the monitor.
Keyboard obviously goes on it too, wolly![]()
free mousematt with the card too ? i see the deal with that mouse.
It look great there.
no more cold forearms winter gaming![]()
It won't be so bad with a free evga mouse .
I am deciding to cancel my preorder 980ti hybrid and just get Titan X or not hehehe
Is it a hard task to retrofit the Hybrid cooler to an EVGA card? Also is it only possible to fit it to an EVGA card?
I'm considering the same thing.
No it's not hard at all (simple instructions).
It fits on all TXs as they are the same PCB.
(Will probably get drunk tonight and order another knowing me!)
