- 2 Apr 2011
MSI's coolers are defo quieter than Gigabyte's from past experience. EVGA sounds like it's in between.
The 780 is a smaller chip and ran cooler than the 980ti does.
Shiver please let us know about when you overclocked your Hybrid ? i'd love to hear more about it .Thanks in advance![]()
So do tell, those who were lucky to get one already. Are they worth it?![]()
Not good... I'll report tomorrow as well. Honestly, silence is an absolute must for me.
taken from overclock forums
"Hi,
at those who have the EVGA GTX 980 TI SC ACX 2.0: Can you tell me please which temperature you reach at 100% fan and 100% GPU load? Is the card then loud?"
"I have two of those. They are pretty loud actually. 100% is obnoxiously loud and you would never want that for extended periods. Over 70% starts to get really noticeable. With 1 card and fans at 70% you are looking at temps in the 69- 72 range at max load. Honestly Id personally go for a different card if I could do it again. Maybe the Windforce or wait for others."
I hope you have a better experience with the ACX 2.0.
Agnes i wonder why didn't you pick Hybrid if your main concern is noise .
1) My budget was £550 to start with, it creeped to £620 with the G1, then went back down to £600 for the ACX 2.0
2) I have a tiny case, Lian Li, no room for a dead rat once the GPU is in, let along a rad
3) If I were to go down the watercooling route, I'll do it properly. Don't like all this 'hybrid' stuff. I guess that's because I'm old school coming from the days when I used to moderate a watercooling forum lol.
Whilst on the note, I am looking into the notion of going watercooled again... Maybe... I'll see, need to find a case I like first. It will be another few hundred squideroos out of my back pocket at least though
Could someone tell me if I need to order certain bolts if I want to use the EVGA hybrid in a push / pull setup?
Ugh, so the ACX is loud. How loud is the reference design in comparison? Any advice as I could just go over to the SC reference and then put this sorry thing to bed as the SC reference is currently in stock.
Its worth noting I have 4 Noctua fans in my case currently alongside a Noctua CPU cooler so would this help with temperatures/airflow?
