If Fury X turns out to faster than 980 ti...will you switch?
Caporegime
30 Jul 2013
Switch from a 980Ti? Seems a bit pointless.
Is there a scenario where a 980Ti at 1440p isn't quick enough?
And if you are running 4k then you'd probably be talking a few fps at most if the Fury X does turn out to be quicker.
20 Dec 2011
Kent
Ill be staying with my 970sli @ 1440p for the moment thanks :)
On a serious note, I am happy with games I play at the moment on 970SLI@1440p. Including mostly maxxed Witcther 3 and Ultimate settings on GTA:V. But, and I'm sure this is, but apart from most enthusiast PC tech consumers who haven't recently bought a Titan X or 980Ti, I will wait till the beginning of 2016, when things will have settled, prices will have stabilized, drivers matured, the second hand market may even be viable.
Then and only then may I look at changing, 980ti SLI is appealing, but Fury X may also be worthy. Who knows.
25 Jun 2009
NO, simply because TX is already way too powerful for 1080p
only upgrade if you're going to switch to 4K which wont be till next year and any upgrade (OBVIOUSLY) will have to be far more powerful than TX.
this can only be a Dual Card.........another TX or next year's TX :cool:
16 Aug 2011
Ireland
I'm on a 1440p screen (have been for a bit now) and while not exactly "switching" as I'm on an AMD card, the two cards I'm paying closest attention too is the 980ti and the furyX (well the air cooled versions if they are the same) - which ever actually has the best performance (in the games I play or expect to play the most this year) will get my money - either side is an option for me and I'l go for whatever I feel is the best option for me :)
21 May 2013
No because I'm still at 1080p xD
If I was upgrading from an older card, I would buy whichever is the fastest in the games I play. If I had a 9-series nVidia card I wouldn't bother because it's too soon to upgrade.
30 Jul 2006
4090 on 850w = BOOM
see I know 295X2 isn't really enough to do what I want to do at 4K so I'm looking at £1000 budget which is probably 2 amd cards or 2 nvidia card if they drop price to counter. Either way I should get a good 50-60% more performance.
25 Aug 2013
London, Northolt
Turn MSAA on and watch your 970s drown
