 - 23 Apr 2013
 - Gggg
I thought Vulkan was literally a fork of Mantle. I could quite easily be wrong, though.
Mantle evolved in Vulkan. Thats a good thing!
Reviews will reveal if stock Fury X is faster, or trades blows with stock 980Ti. Remember Custom cooled 980Ti cards are faster than stock. I would assume (maybe wrongly) that AIBs can customise their Fury X cards with custom PCBs, higher stock clocks and even better AOI coolers.
Interesting times ahead for both Nvidia and AMD.
Guys. I've a 780T case, with a Corsair H105 in the roof, the radiator of that occupies 2 120mm fan positions leaving room for a 120mm fan as shown below
Would it be a good or bad idea to put the FuryX radiator and fan to the right of the H105 in the roof so all my rads would be at the top? see below, it's really cool up in that corner just above the DVD Drive.
Refining as in getting better yields. If they can't do that then did Nvidia intentionally release the 980 at lower speeds to milk the buyers before releasing the 980ti? They are on the same process after all..
edit: Maybe AMD have released the FuryX at an intentional lower speed to match the top end Nvidia cards for now and then release a superclocked Fury later on to deliver a killer blow...Interesting.
Well, if I recall correctly the fury is slower than the fury X, but there will only be one design for the fury X.
This is why some tricks will be needed from ATI.
I'm directly comparing it against the 980-ti because I'm sitting on the edge of a full new build & it's between SLI 980-ti & Cross-fire Fury X. Deep down I want the Fury X to edge ahead because I do like AMD, but if the performance of the 980-ti (G1) is noticeably better then I'd have to go that route.
As mentioned earlier, it all relies on unlocking the voltages & what the Fury-X can handle. It touted as being an over-clockers dream. The question is, was that marketing BS or are they waiting with an ace to reveal soon to knock it ahead.
The framework of the incredible cooling & high power capacity is there, it's down to the chips resilience, ATI's lock down & the silicon lottery.
stick it where the back fan is ???
The 980 is a completely different chip GM204, to the 980ti GM200
My home machine is 1080P and the games I play hardly tax such cards.
 You need to get that sorted. If only there was somewhere you could go to get something with more pixels.Guys. I've a 780T case, with a Corsair H105 in the roof, the radiator of that occupies 2 120mm fan positions leaving room for a 120mm fan as shown below
)Lets say the benchmarks are real for a moment.what will the performance difference be between fury x crossfire and fury x2 ...i want to justify for waiting for the next top amd card . I know it will have double the vram but what else?
Hi, currently there is nobody here that would be able to answer that for you. The specification for the Fury X2 are currently an unknown, it could possibly be lacking the same shader count as the Fury X or be limited by TDP
Im sure someone else can answer it better than you have.
Could you not remove the Drive cages and find somewhere else to mount them like at the rear of the case, leaving you ample room at the front to mount the Fury X cooler or even two in crossfire?
 all my hard drive are mounted inside the 5.25 bays.Hi, currently there is nobody here that would be able to answer that for you. The specification for the Fury X2 are currently an unknown, it could possibly be lacking the same shader count as the Fury X or be limited by TDP. Also Fury x2 will very likely be limited to 4GB HBM per core as are all Fiji products. VRAM does not scale with Crossfire.
