Tearing? There is no tearing @ 4K 60Hz.
You're in luck AMD lowered prices on their r290. I'm waiting for the Fury X dual GPU out this fall
That is one of the options you give us! I would wait for the Fury X dual GPU and get that one. If your finances doesn't allow that expenditure, then get the R290 for a Crossfire setup.So are you saying buy another R290 and crossfire it?
I have aR295X2. When viewing Windows, only one is active and I get no lag @ 4K resolution. If you're a gamer, I suggest a dual card setup.
I'm a gamer so want the best games looking the best on the best monitor.
Been a while since I upgraded so I might as well get this monitor and a new card.
Looking at the fury it does seem good but it seems that the Titan cards are better.
Will take this to the graphics card section now as I think I'm going off topic.
Monitor is defo bought, now I just need to ensure I get the right card to get the best out of it.
Thanks all.
I took delivery of this monitor this morning from OcUK, and it's simply stunning!
The sheer size of the screen and the quality will impress anyone. The blacks look great being a VA panel too. I upgraded from a Asus VG278HE 27".
I don't find it too reflective myself!
Come to think of it, I've actually never once thought... oh damn... screen reflection...
Just been driving round in GTAV from night to day and it looks stunning! Took a yacht for a spin around the coastline and the 4k at high settings is absolutely beautiful.
Can't really say on the lower scale resolution, as I'm running a Titan X and it's 4k-ing the heck out of everything nae bother!
To be honest... I don't know why anyone would buy a 4k monitor if they don't have the GPU juice to run it???
^^ For Ultrawide screen and screen real estate or eye sight issues
I was running this monitor at 2650x1440 for a day or two before my new DP cable arrived so can confirmed it scales well to this size atleast, I also used the AMD CCC option "GPU scaler" which seemed to work OK.
As for other resolutions I run a custom size with Custom Resolution Utility (CRU) of 3840 x 1607 and 3840 x1440 which works very well - am using these for FPS and certain RPG's for the wide view aswell as for games my soon to retire 7970 GHz cannot cope with.
Screen reflection I only notice on loading screens in the day time when the majority of the screen is pitch black, otherwise I think it helps give the colours a vibrant look. Prefer it over my matte ASUS.
Resolution and refresh rate don't dictate tearing. It's an issue between gpu fps and refresh rate being out of sync.
