from the AMD update
"Frame Rate Target Control™ (FRTC)
FRTC allows the user to set a maximum frame rate when playing an application in full screen exclusive mode. This feature provides the following benefits:
Reduced GPU power consumption
Reduced system heat
Lower fan speeds and less noise
This feature is supported on applications using DirectX® 10 or higher and on the following AMD graphics products:"
Does this mean using MSI afterburner to limit your frame rates is no longer necessary?
Reduced system heat
(if you are sane and do not set the graphics to Ultra low)
