- 7 Feb 2014
- Lancashire
ADVICE PLEASE
I'm thinking of replacing the stock fan with a pair of Corsair Fan, SP120 PWM High Pressure Fan 4 pin, Dual Pack (CO-9050014-WW).
As the rad' only has 1 fan on it which screws do i need to purchase to add a second fan. Also which fan splitter will I need for the power please.
Is it a 3 pin to 4 pin or a 4 pin to 4 pin splitter?
Thanks H.
They are m3 or m4 screws I think, you can check by measuring the diameter of the original screws in mm.
Length depends on how thick the replacement fan you are fitting is, if it's the same thickness as the original fan then you need the same length as the original screws. If not then compensate, just be careful you don't try fitting screws that are too long or you could puncture the radiator
