But do they run cooler?
I think i've knocked a good 5 degs off mineBut do they run cooler?
Just measured. 3mm including the pads. You might get vibration if touching.EXACTLY how thin are they? My CPU cooler comes VERY close to the GPU. Would it matter if they touched?
Ah I see. Only problem there is the sp are 4 pin and the connection on the gpu is 2
Got me the EVGA Titan X Hydro kit coming soon![]()
So they're available now? I've not had an email. Caseking let me down![]()
