Err. It says 34.4 on the advert for urban![]()
Well yeah, but I was hoping for some confirmation on weather the lab tests were on the mark or very optimistic for that particular figure. 34mpg would be pretty good going for a 1.8.
They're pretty good on fuel really, knock 10-15% off that and you won't be far away.
Driven appropriately of course
Ah ok thanks, bit of a pain to fit though I believe
Sounds great. Thanks
When I was looking for them on another forum, I did see your car up for sale too (/stalker). Looks very nice but out of my budget
Good luck with your sale![]()
Thanks, tbh I've made zero effort to actually sell it just left it on there really to see if there's any interest!
They're (fn2) no good if mpg or comfort is of any real concern anyway
Doesn't look to be a job.
My brother has got an EP3 04 Civic Type R and needs some work done, which I'll be doing.
1. Change drivers side wing - Is this a nightmare? Side skirt looks to be bonded on as well as screwed. Tiger seal sufficient? Does the front bumper have to come off?
2. Service - I've heard the fuel filter is a nightmare to do, is this true? The rest of it should be straight forward (Oil, Oil Filter, Air Filter, Pollen Filter, Spark Plugs, etc). Anything that's awkward out of this?
3. His rear pads are very low, particularly on the drivers side. Are the calipers known for sticky pistons/sliders? I'm hoping they aren't seized and I can free them off but are there known issues with them? I'd like to avoid replacing them if possible.
Cheers.
1. Side skirt is not bonded on but needs to be removed to take the wing off. Two bolts in engine bay under the plastic cover, 2 more bolts behind the plastic cover (Clips off) next to the side mirrors and one more bolt right at the bottom behind the side skirt and it comes off, takes around 15 mins to do.
2. Fuel filter is bit of a nightmare and can be done but to be honest, they don't need doing, I dont think I've ever heard of Type R's having fuel problem due to a bad or dirty filter and I go through tons of these cars. The rest is very easy to do.
3. Seizing or sticking calipers is a common fault with all EP3 Type R's especially the rear ones as people over look them compared to fronts. You can get replacement pistons, seals and all for not a lot of money although I would spend a tiny bit more and just get replacement calipers. I think a front caliper is around £70 each with your old one in return from Euro car parts and rear around £60. Quite simple to swap around aswell if you know what you're doing.
Hope that helps, anything else, Just ask![]()
Isn't Ford Focus RS a big competition to this Civic because its;
- Cheaper
- More Powerful
- AWD
