What you need to do Gregster is every time you see a new graphic card and you start to break out into a sweat tell the Mrs to give you a slap.![]()
She does that every time I mention new hardware and start dribbling
I'm excited by the imminent death of silicon, it may yield the most exciting time since the advent of the integrated circuit; gallium arsenide, silicene, graphene, optical computing... who knows what the graphics cards of the near future will be made of? All I know is that it will beat another four years of 28nm respinshttp://www.kitguru.net/components/g...0nm-elements-on-track-for-production-in-2018/
No more nodes left.
Only fake ones from here on out. Which means doom & gloom for enthusiast chips. What on Earth will happen?
No more nodes left.
Businesses tend to be conservative by nature, especially when they have billions of dollars invested in the existing infrastructure.If they had just spent the money on graphene/whatever we wouldn't have to endure this.
Hopefully,then they can actually play games instead of all the E-PEEN wars??
http://wccftech.com/nvidias-gp100-pascal-flagship-pack-4096-bit-memory-bus-8hi-hbm-stacks/
Flagship GP100 will have 4096 bit memory bus and 8 Hi HBM2 stacks. The Titan X successor will have 8 Hi HBM2 stacks with 32GB memory while GTX 980 Ti successor likely GTX 1080 Ti will have 4 Hi HBM2 stacks with 16GB memory.
Exclusive: Pascal has a Killer performance
Pascal technology will have as many as 17 billion transistors under the bonnet, Fuzilla can exclusively reveal.
Pascal is the successor to the Maxwell Titan X GM200 and we have been tipped off by some reliable sources that it will have more than a double the number of transisters. The huge increase comes from Pascal's 16 nm FinFET process and its transistor size is close to two times smaller.
Nvidia Pascal GPU has 17 billion transistors
I was so close to pulling the trigger on a 980 Ti last month, but didn't because I couldn't justify to myself spending that sort of money on another 28nm GPU; reading that article makes me feel a whole lot better about that decision, Pascal is going to be a beast!Nvidia Pascal GPU has 17 billion transistors
