Speaking of dithering, read this Philips 40" thread: http://forums.overclockers.co.uk/showthread.php?t=18634255 and in particular the rave reviews from Elite aficionados before you give up hope.
Lads what calibration tool did ye use. Im tempted to get the X-Rite i1Display Pro
this is the settings I used may or may not be any use to you
magic bright: custom
brightness: 50
contrast: 75
gamma: mode 3
rgb
red 45
green 46
blue 50
I then used the graphics control panel to lower the gamma very slightly to give the colours a bit more pop without spoiling the brightness
There was a chart on Family GuyOn another note, does anyone know is there a test for blacks?
Im not sure to laugh or cry.
Got home and turned on the pc and was wondering why the monitor wasnt turning on. I think it could be dead. I tried turning it on via pressing the button on the back in getting nothing
Anyway I can find out is the power brick dead or the monitor dead?
I don't know much about monitors.
But when I had mine I hooked it up via the supplied HDMI cable.
I used it for a few days and then noticed it was only running at 30hz.
I swapped to display port and Im now back at 60hz.
I'm not sure if it was the cable or my graphics card.
With this particular monitor 30Hz is the maximum refresh rate when using HDMI. Only DisplayPort will support 60Hz. I believe this is due to the amount of bandwidth supplied by HDMI vs DisplayPort.
Personally banding does my head in. Just how bad is it?
Unfortunately it was also noticeable in a lot of content. When using HDMI, I can barely make out 254 square, however, there is virtually zero banding then.When using display port on my 29um65, I could make out 254 square easily, however, the gradient looked AWFUL, it looked like a really bad paint job as in you could easily see the individual strokesUnfortunately it was also noticeable in a lot of content. When using HDMI, I can barely make out 254 square, however, there is virtually zero banding then.
