I didn't doubt you lol. One thing I have seen though with these xenon sis that people have set multipliers but they are running at that when u check them?
I'm mulling over installing a HyperX Predator PCIe SSD in a few weeks to bypass the lack of a decent onboard SATA3 controller, anyone else done something similar? I'll also be replacing my 670 SLI with a single card at the same time and thinking of going 980Ti.
Oh yeh, I have hwinfo64 running and set to display cpu speed, temps, etc, in my Logitech G15.
When I ran cinebench I had hwmonitor, cpu-z and hwinfo64 running, all displaying 4.4ghz.
why didn't I find this thread a year ago?
I thought 5650 had a 20x multiplier? Confused now
I'm glad to see you have the same board as me so I'll be picking your brains fro settings![]()
Clock speed probably. The i7-980X was 3.33 GHz at stock, the fastest Xeon equivalent is the X5675, which is 3.06 GHz. The Xeon equivalent of the i7-980X (the X5680) has a TDP of 130 W.can somebody answer me why the TDp of these xeons are only 95W but he 980X is 130W?
I see you can get some hex core xeons with TDP of 130W. Is 130W better than having a 95W one or vica versa or means nothing?
Ive been out of the loop for over two years and I "know nothing"![]()
Check the review I linked to. They found no difference between a GTX980 at 4K running on PCI 3.0 x16 and PCI 2.0 x16; and PCI 2.0 x8 only had a 2% drop in performance.
I do not believe a 980Ti will be hampered by the x58 chipset.
thanks for this thread i upgraded from i7 930 @4.20 to xeon 5670 @4.51Ghz Daily
i know you want to know what volt ( it is 1.429v in cpuz) i did it for months no there degradation
i was think before if we past intel recommendation 1.35v will there degrade for cpu or kill it but after deep search about oc i7 980x i found a lot of overclocker who use 1.5v Daily for more than year without degradation
and i ask one of them and see what he answer
i learned if you have good cooler and good temp you always can overclock more no matter what volt
i try overclock 4.70Ghz and rease vcore to 1.55v but no stability i think there something make it no stability other vcore but i don't know what it is
i think 4.51Ghz is very good overclock and no need more overclock so i am happy with it
sorry for bad english
