I don't mind if it is just normal rain but the roads are flooded and there is standing water everywhere.
Luckily I can just drive my car when the weather is like this![]()
Why cant you ride it in the rain?
Lucky u stuck your L plate back on then
Fitted a GPR Furore can to my ZR7
Adjusted my chain today for the first time. Can't believe how easy it is on a single swing arm. Loosen a bolt, rotate the eccentric adjuster thing (I think that's what they call it), tighten bolt back to 55nm. No lining up, no starting again if you get it wrong.
Not sure how I'll ever get a bike with 2 swingarms now. This Speed is so easy to maintain![]()
Wheel removal is stupidly easy too if it's the same as on a ducati, no messing around with chain tension, just whip the nut off and slide off the wheel.
kinda want it![]()
where's the pillion sit and you can't pull a wheelie on it haha
