- 18 Oct 2012
meh, requested refund, completely unplayable with a pad, as I expected.
its playable, just hard, and not as good results as a wheel, but definately playable.
First top 10 in the stratos, by far my best drive.
Playing fine with xbox pad here, you obviously just suck at sims![]()
It must have been a controller set up problem or something but it just wouldn't hold a straight line for love nor money, just pinging the stick from one side to the other to try and correct a never ending tank slapper.
Can you imagine what would happen if you turned the wheel from full lock one way to the other in a tenth of a second in a real car on gravel at speed? .......
No ****, I've been doing track days for 20 odd years and owned umpteen big power RWD cars so I'm not an idiot, I was referring to how it was behaving with a controller and it's complete lack of ability to stick to a moderate line.
Could anyone help me?
Since the last update I haven't been able to drive at all because my wheel feels like it's just spinning with no FFB it's so weak. What is the best way to change this? (And is there a generally accepted good set up for a logitech DFGT?)
Cheers!
Tidds2 have you tried Dg's settings see Dg's post, in Degree's of rotation you can set it from 200 upto 540 - http://forums.overclockers.co.uk/showpost.php?p=28315145&postcount=1699
In Vibtation & Feedback try Self Aligning Torq - 10%, l find 12% feels better.
Advanced Wheel Opt - Soft Lock - OFF > click Load/Save Device Config.
These settings are a good starting point.
It is a hard game with a controller, I hate how you have no steering unless you are accelerating, If you brake and then release the brake and try to steer with out accelerating again you get nothing, no turn at all. Or at least I don't. I'd hate to think it was only me.
That's even worse than it was im afraid![]()
