MSI Gaming any good for SLi or it going to suffer from the custom cooler with the top card struggling to get airflow?The msi simply doesn't make noise. Its quieter than an aio cooled fury x. Fan at 80% when overclocked. Still cant hear it. Downside, you notice other fans/components are loud because they were previously masked by loud idle gpu fan noise.
Should I use a custom bios for OCing my MSI 6G with 63% asic, or is it unnecessary?
It's a lame bios setting which many (if not all) custom Ti have. Mine does it to. It does go away with a custom bios (or with an AIO lol), but as you say it's just 12Mhz.
Here a question. Got my 980ti connected to a single block connector from my superflower 1300.
The GPU PSU cable has an 8pin and the another 8pin daisy chained off it.
Should I actually be using seperate connections?
As above really. See what you get on stock.
I'm bench stable at 1480-1500.
Games stable at roughly 1420.
Shame as my asic is 70.3 I thought id get more. Just get nvlddmkm errors fast, very little artifacting.
Still 1400 is still blistering quick...and just toys with me to get another![]()
