***Intel i7 4790K Owners thread***
6 Oct 2004
Southampton, UK
Ok my new rig is up , but I'm a bit nervous about the temps on this new CPU.
I'm running a H110i GT on top of a Define R5 in a push configuration , blowing out. I'm seeing temps of 83C using Intel Burn Test measured by HWMonitor !?
Intel XTU is showing 68C Max when doing a 5 min stress
By default the motherboard puts the CPU VCore to 1.267v
I have undervolted my CPU to 1.150v and it has dropped my Intel XTU temps to 60C when doing a 5 min stress test .
Coming from a i7 930 I'm not used to this kind of heat. I had a read on the internet , many have suggested this is normal for a 4790K.
Guess I'm expecting too much from this CPU :D
9 Nov 2002
Surrey, UK
Run Intel Burn Test often do you? :D
These newer, smaller process CPUs just don't have the surface area to get rid of heat quickly enough when you put them under unrealistic stress (IBT or Prime95 small FFT), or a stupid amount of voltage through them (extreme OC with liquid nitrogen).
Don't worry as long as your everyday workload is keeping the temperatures down at more sane levels.
6 Oct 2004
Southampton, UK
Haha that's the general consensus I get from reading around.
Well I'm getting about 62C Max @ Stock Vcore (1.267v) on playing GTA V atm. Idles about 29-32C anyways.
Cheers :D
16 Jan 2006
Normal
23 Oct 2002
Cheltenham
New chip in, seems to clock well but things are getting a bit warm. So far I'm at 4.8 at 1.27 but under Aida temps are getting up to 90 every now and again although generally floating around 80. Up to 2 Hours in Aida now and things are stable so fingers crossed.
Cooler is a Megahalem with an Apache fan Tim is Thermal Grizzly Kryo. Do these temps seem as expected for this combination at this speed/vcore?
4 Feb 2006
IBT seems to boost voltage higher by around 0.0.5V at certain points in the test hence the higher temps. On mine it actually hits 100C @ 4.7GHz 1.3V (boosts to 1.35V in IBT) so I don't use it at all. You could get around this voltage boost by fixing voltage in bios but then you wouldn't get the energy saving benefits of auto voltage control.
For general stability testing use an old version of Prime95, Intel XTU or Asus RealBench.
23 Oct 2002
Cheltenham
Spoke too soon, looks like its fallen off the network. will have to have a look when I get home. At least I don't seem to have hit the 4.7 wall others have with it already being stable for 2hrs in Aida.
C64
C64
16 Mar 2007
London
You stress test with manual voltage find the stability then use adaptive voltage
7 Mar 2005
If found something useful today, if I fix my voltage at what I need it to be (1.185v), and enable C1 and C3 power saving states, the CPU will still ramp it's voltage down to ~0.73 when speed step kicks in. C6/7 cause the idle volts to drop even lower, but I'm concerned that this will introduce lag as the CPU ramps up.
This for me is better than adaptive or offset voltage, as I use a negative offset which normally makes the idle and non turbo volts too low. Now I can have the best of both.
6 Jan 2013
Rollergirl
I'm trying to fine tune my OC. I've got it stable at 4.7 but I'm trying to push further. I'm currently at 4.8 with 1.34v but Realbench keeps failing the video encode section.
I've really just set XMP, upped the multiplier and upped the vcore to get where I am. So I think I need to fine tune.
The problem for me is understanding the ASUS terminology in BIOS. What is the terminology for the following :
VRIN Override volts
CPU Ring volts
Any guides for 4790k on ASUS BIOS would be warmly welcomed. :D
4 Feb 2006
VRIN Override volts
CPU Ring volts
These guides may help..
http://overclocking.guide/asus-maximus-vii-ranger/
http://rog.asus.com/254052013/maximus-motherboards/recommended-settings-for-overclocking-maximus-vi-motherboards/
The ring voltage is same as cpu cache voltage it seems.
6 May 2012
Wigan
VRIN Override volts
CPU Ring volts
http://forums.overclockers.co.uk/showthread.php?t=18687108
Posts 8 and 9 are on Asus mobo's
Caporegime
14 Dec 2005
armoy, n. ireland
Also, regarding input. I've found that you don't have to bother touching the initial setting, just the eventual input one. Its generally accepted that input should be at least 0.5v higher than vcore. Ie in my case, 1.300 core = 1.800 input.
4 Feb 2006
I've even tried upto 2.05v input voltage but made no difference when trying for 4.8GHz so best to leave it on auto.
