Can someone recommend me a diver's watch(not actually a diver, just prefer the look of them) for around £100?
I have seen a lot from Seiko but dont know which ones good for the price.
Thanks.
edit: Also like the looks of the Orient Ray/Mako. What are the chances of the watch being fake?(if possible) when buying from an eBay store/seller.
Massdrop have the Seiko SNZH range for about that, not really a true divers watch as it doesn't have a screw down crown.
Alternatively you can find a seller on Rakuten and get a Seiko SKX007 or 009 for around £80 and that's a proper ISO certified diver that will outlast you. There's a store called "seiko specialty store 3s" on Rakuten that I used and they were good - you just have to use google translate.
Orient Ray is a good shout too, screw down crown and it's a nice size and quite low profile whereas the Seikos are a bit chubbier. Cost me about £65 from Massdrop.
Speaking from experience for all 3 because I have too many watches... My wrist is just under 7" for reference.
SNZH53
SKX009
Ray
Others worth looking at are the Seiko SRP309 "Orange Monster" and the SNZF17.
