- 6 Jan 2013
- Rollergirl
This game advertises an i7 as recommended. How does it run on an i5?
Is it worth playing? I have not played it or even installed it yet.
I think so, but i'm one of the lucky ones that's never had an issue with the game.
Well I'm 12% in after using the Steam tool to make the game playable, does all the Batmobile stuff calm down or reduce in frequency because its already doing my head in?
What kinda settings you running? ultra
Hairworks? Wouldn't that be Cowlworks?Everything on, hairworks the lot.
Hairworks? Wouldn't that be Cowlworks?![]()
I'm stuck.. How do i get past this bit?
Nearing the end of the scarecrow missions and i've taken off my belt and gadgets and now I am faced with loads of Jokers.
I spend 5 minutes or so killing them and get like 100 hit points yet nothing happens.
You have to keep doing the Joker takedowns it prompts you to after getting a 5 hit combo. I think it's 5 or so takedowns.
Dear Batman: Arkham Knight PC community,
The teams have been working hard to address the issues with the PC version of the game. We are happy to confirm that we are now putting the first interim patch into testing. If all goes well, we expect to issue the patch in the next few weeks. We’ll be sure to report back in the next two weeks on how the testing is coming along.
Below are some of the major fixes and improvements you can expect in the upcoming patch:
• Reduced frame rate hitches
• Optimized system memory and VRAM usage
• Improved performance on all GPUs (requires the latest drivers)
o Min Spec AMD GPU is once again the Radeon HD 7870 2GB
• More Robust In-Game Settings, including:
o Added the ability to change settings for Max FPS to 30/60/90
o Added toggles for Motion Blur, Chromatic Aberration, and Film Grain
o Added a “High” Texture Resolution value
o Added Texture Filtering option
o Added an Adaptive V-Sync option (NVIDIA only)
o Added VRAM Usage Meter
o Added Mouse Sensitivity Slider & Mouse Smoothing Option
• Fixed low resolution texture bugs
• Fixed hitches when running on mechanical hard drives (HDD)
While our first priority is fixing the issues listed above, the team is continuing to work on the following:
• Skipping the boot up splash screens
• DLC/Season Pass content
• Additional updates such as Photo Mode
We again thank you for your continued patience as we work on these issues. As always, we are continuing to monitor and listen for any additional issues.
- Warner Bros. Interactive Entertainment
