- 29 Dec 2004
- Shepley
Loosen stem bolts, tighten up top cap until play is *just* eliminated, tighten stem bolts.
If tightening the top cap fully does not eliminate the play, you'll need to add a spacer on top of the stem to give you a bit more adjustment room.
