@ ViRuS2k,
What guide did you follow, will be doing the same when my HG612 arrives
Its actually quite easy.
i have set it up so that my asus router is on 192.168.1.2
i have set    up my BT modem hg612 is on 192.168.1.1
so i can access both modem and router at the same time
Method i used was plug the modem in and connect it to your pc on lan port 2 of the modem
then flash the p80 firmware it is the latest version that is reference unlocked with G.IMP fully working as well as GUI and telnet access.
Make sure you flash the unlocked p08 GUI version
then to unlock the router follow these steps....
1: change your pc lan port to 192.168.1.100
then change subnet @ 255.255.255.0
then change Gateway @ 192.168.1.1
then hold down the reset button on the BT modem with it connected to your pc and lan port 2 on the BT modem power the BT modem holding down the reset button then let go of the reset button after 10 seconds you will see the power light on the router flickering
once done and the BT modem is fully powered back up gain access to the firmware flashing page of the router with 192.168.1.1
then browse to the firmware and press ok, then wait about 3 minutes to make sure the BT modem fully flashed and upgraded.
do not try to flash any firmwares in the future from within the GUI of the modem as the firmware will not fully flash
ok then your done.
now to set up, plug your asus router into your pc and then plug the other end into the routers lan port 2
then plug the modems cable coming out of lan port 1 into lan port 1 on the router.
then connect the adsl cable to the BT modem
Then power up the asus router and go into the LAN settings / Dual WAN and set Primary wan @Ethernet wan / Lan port 1 *as this will be the port your plugging your BT modem into.
after that go to LAN settings on the asus router : Ip address set as : 192.168.1.2
with subnet @ 255.255.255.0
then apply and wait, then once back in the router from accessing it @ 192.168.1.2
go into Lan Settings again DHCP server tab, then make sure your settings look like this :
Ip pool starting address : 192.168.1.3
Ip pool ending address :  192.168.1.254
Default gateway : 192.168.1.2 (if you leave this default as in black you will not be able to access the modems gui @ 192.168.1.1
so change it to 192.168.1.2 then click apply
ok thats the router settings done.
now power off the router and then power on the BT modem give it 1 minute then power on the router,, then you should get a internet connection and be done you should see the light on the routers Internet light go on
if the internet light does not go on, you might need to go into the modems gui and configure it to access internet mine worked without even messing with settings lol
to get access to statistics from other programs ect ect like the picture i posted above, you will need to use the modems lan 2 port and plug that directly into a spare port on the router that will also let you access the modems gui @ 192.168.1.1 without that cable plugged in you will not get GUI or TELNET or STATS access from the modem.
once you plug that in the asus router should give you access @192.168.1.1 from the get go as we set the router up to use 192.168.1.2 as the modems default is 192.168.1.1
hope this helps if you get stuck just let me know im sure i can fix it for ya
