seems fine to me mateAnyone go the 60mm Olympus macro?
How well does it focus at the close end of the scale?
I've had one for about 12 months and getting increasingly annoyed with its reluctance to autofocus at close distances.
I have double checked the focus dial is correct.
Given the manual fo us is tedious to use it has somewhat soured my M43 experience lately![]()
it depends on how close i want to be and if i want 1:1 or not, but if your after max mag then man focus works better on any system/make. the above shot is hand held and auto focus but remember at max mag you really are better off with a tripod, the slightest movement with the really shallow depth of field and that's focus lostHow do you set the focus dial on the side of lens?
Wondering if I am using it wrong.
I can get the minimum focus distance, but either have to use manual focus or I set the switch to minimum and then let it refocus as I move back slightly.
That works fine.
I think on the dial, going clockwise I use the second setting.
Niko,
Could I ask a flavour? Would you mind posting/linked a 100% of the above shot? I fancy a pixel peep
Also what camera do you use?
Totally understand if it's a no![]()
hi mate pic was a bit big for here, so do you have an email addy I can send you the link to? trust it to me and i will get it sorted, but yep as mister insaneNiko,
hi mate pic was a bit big for here, so do you have an email addy I can send you the link to? trust it to me and i will get it sorted, but yep as mister insanesaid for cam/lens
it depends on how close i want to be and if i want 1:1 or not, but if your after max mag then man focus works better on any system/make. the above shot is hand held and auto focus but remember at max mag you really are better off with a tripod, the slightest movement with the really shallow depth of field and that's focus lostas is in a slight breeze
its frustrating trying to get "that shot" using off camera flash helps a lot.I do try to use tripod and manual focus when possible but I,often have a roam around the garden and get in amongst the flowers so not always possible without getting tangled up or shouted at for trampling.
I hate a breeze though. i can get really wound up sometimes when something moves just as go to press the shutter.
I'll have a play around at the weekend and try and refine my technique!
right i tried to email a link but i don't think its worked, let me know please i can try a different email to send from if its failed
