Anybody else having issues with their keyboard since the last firmware/ software update?
Mine just randomly is no longer detected by CUE. Can restart the PC, move the keyboard USB it doesnt matter, the only way to get the keyboard working again is to reinstall CUE. Should say the keyboard works fine throughout, but it defaults to the red and white colour.
Plugging the keyboard in, it works fine - until you hear microsoft chiming in, that is. Check the device manager, and lo and behold device descriptor request failed.
You need CUE for anything other than basic typing.
If there's one thing I want, it's for CUE to have the ability to update without me having to go to the website, select my peripheral type, scroll the list for the applicable product, manually download the .zip, extract the zip and then install it, as if it's the first time I'm doing it.
That, or the ability to turn auto updates off.
/semirant
