That'll do it!
Took the back end off mine last night as it's become hard to start again as the starter is strugling. Took a small screwdriver to all the plugs feeding from reg/rect and scratched up the connections and then WD40'd for good measure.
Tested with multi meter and it is a bit down on voltage when revving but I'm not expecting much as the battery was pretty low when I started.
However it must have done the job as it started 5 times one after another so easily after leaving it idle for a 3-4 mins.
I think she just wanted some attention tbh
