- 2 Jan 2012
- UK.
Think my playstation may be on its way out, so far this week when ive switched it off after few minutes it will give the 3 beeps, if theres a disk in then it will spit it out and switch itself back on and beep away and weird noise come from the disc drive, so far has happened 3 times.
Yeah this is the eject disc tray error that my early revision PS4 had as well, if it keeps making the noise even without a disc in the tray. It's basically constantly trying to eject a disc >> http://faq.en.playstation.com/app/answers/detail/a_id/9939/~/the-ps4-automatically-ejects-a-disc
You can stop it doing this my unplugging the PS4 and holding down the power button for about a minute, then leave PS4 unplugged for about 3-5 minutes, plug back in and power it back on and get it will run a HDD check, for some reason this fixes the error but it's not permanent.
That's why I went and bought the new model, as it comes with physical buttons (Not touch sensitive static based) so tray eject error won't happen anymore. You can remove the rubber on bottom of console to fix the error but then I think warranty is invalid, better to RMA or buy the new revision and pass your older console on.
